Saltar al contenido principal
Jam Voice Battery Replacement
Qué necesitas
  1. Jam Voice Battery Replacement, Hard Mesh Cover: paso 1, imagen 1 de 2 Jam Voice Battery Replacement, Hard Mesh Cover: paso 1, imagen 2 de 2
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Battery Replacement, Motherboard: paso 2, imagen 1 de 1
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Battery Replacement: paso 3, imagen 1 de 2 Jam Voice Battery Replacement: paso 3, imagen 2 de 2
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Battery Replacement: paso 4, imagen 1 de 1
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Battery Replacement: paso 5, imagen 1 de 3 Jam Voice Battery Replacement: paso 5, imagen 2 de 3 Jam Voice Battery Replacement: paso 5, imagen 3 de 3
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Battery Replacement: paso 6, imagen 1 de 1
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Battery Replacement: paso 7, imagen 1 de 2 Jam Voice Battery Replacement: paso 7, imagen 2 de 2
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
  8. Jam Voice Battery Replacement, Battery: paso 8, imagen 1 de 3 Jam Voice Battery Replacement, Battery: paso 8, imagen 2 de 3 Jam Voice Battery Replacement, Battery: paso 8, imagen 3 de 3
    • Expose the motherboard and battery and place in a position that will be easy to access and work with.
    • Use tweezers to remove the battery's wire from the motherboard at the connection point.
    • The battery's connection point is opposite the speaker's connection point.
    • Pull the battery from the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 566
