Saltar al contenido principal
Jabra Speak 510 Motherboard Replacement
Qué necesitas
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: paso 1, imagen 1 de 2 Jabra Speak 510 Motherboard Replacement, Outer Casing: paso 1, imagen 2 de 2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: paso 3, imagen 1 de 2 Jabra Speak 510 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: paso 4, imagen 1 de 3 Jabra Speak 510 Motherboard Replacement: paso 4, imagen 2 de 3 Jabra Speak 510 Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 Jabra Speak 510 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: paso 6, imagen 1 de 1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: paso 7, imagen 1 de 2 Jabra Speak 510 Motherboard Replacement: paso 7, imagen 2 de 2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
Conclusión
4 personas más completaron esta guía.
Jordan Murphy
Miembro Desde 02/16/16
717 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-3, Harley Spring 2016 Miembro de IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Miembros
8 Guías creadas
3 comentarios
Great walk-through... thanks
Walaa Maher - Contestar
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - Contestar
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 76
Todo El Tiempo: 7,625
