Saltar al contenido principal
Jabra Freeway Antenna Replacement
Qué necesitas
  1. Jabra Freeway Antenna Replacement, Front Panel: paso 1, imagen 1 de 3 Jabra Freeway Antenna Replacement, Front Panel: paso 1, imagen 2 de 3 Jabra Freeway Antenna Replacement, Front Panel: paso 1, imagen 3 de 3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Antenna Replacement: paso 2, imagen 1 de 3 Jabra Freeway Antenna Replacement: paso 2, imagen 2 de 3 Jabra Freeway Antenna Replacement: paso 2, imagen 3 de 3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Antenna Replacement: paso 3, imagen 1 de 3 Jabra Freeway Antenna Replacement: paso 3, imagen 2 de 3 Jabra Freeway Antenna Replacement: paso 3, imagen 3 de 3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Antenna Replacement, Antenna: paso 4, imagen 1 de 2 Jabra Freeway Antenna Replacement, Antenna: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Carefully remove the rubber gasket using the tweezers.
  5. Jabra Freeway Antenna Replacement: paso 5, imagen 1 de 2 Jabra Freeway Antenna Replacement: paso 5, imagen 2 de 2
    • Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
  6. Jabra Freeway Antenna Replacement: paso 6, imagen 1 de 3 Jabra Freeway Antenna Replacement: paso 6, imagen 2 de 3 Jabra Freeway Antenna Replacement: paso 6, imagen 3 de 3
    • Remove the microphone from microphone slot using tweezers.
  7. Jabra Freeway Antenna Replacement: paso 7, imagen 1 de 3 Jabra Freeway Antenna Replacement: paso 7, imagen 2 de 3 Jabra Freeway Antenna Replacement: paso 7, imagen 3 de 3
    • Excessive force may cause the circuit board to break, destroying the device.
    • Carefully use the plastic opening tool to lift the circuit board up.
    • The orange portion of the circuit board is glued into place, and a small amount of force is necessary to break it free from the adhesive.
  8. Jabra Freeway Antenna Replacement: paso 8, imagen 1 de 2 Jabra Freeway Antenna Replacement: paso 8, imagen 2 de 2
    • Use the tweezers to remove the antenna from the retaining clips.
  9. Jabra Freeway Antenna Replacement: paso 9, imagen 1 de 1
    • Desolder the antenna wire from the circuit board.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
Conclusión
Alec Wilson
Miembro Desde 10/19/16
741 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 4-8, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 826
