Saltar al contenido principal
Jabra CRUISER2 Speaker Replacement
Qué necesitas
  1. Jabra CRUISER2 Speaker Replacement, Front Plate: paso 1, imagen 1 de 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Instrucciones de iOpener
  2. Jabra CRUISER2 Speaker Replacement: paso 2, imagen 1 de 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Speaker Replacement: paso 3, imagen 1 de 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Speaker Replacement, Speaker: paso 4, imagen 1 de 2 Jabra CRUISER2 Speaker Replacement, Speaker: paso 4, imagen 2 de 2
    • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
  5. Jabra CRUISER2 Speaker Replacement: paso 5, imagen 1 de 1
    • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • The screwdriver sizes are located on the sides of their heads.
  6. Jabra CRUISER2 Speaker Replacement: paso 6, imagen 1 de 1
    • Gently pull the black and red wires away from the back plate to remove the speaker.
  7. Jabra CRUISER2 Speaker Replacement: paso 7, imagen 1 de 2 Jabra CRUISER2 Speaker Replacement: paso 7, imagen 2 de 2
    • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
Conclusión
Spartacus
Miembro Desde 10/17/14
636 Reputación
5 Guías creadas
Equipo
Baylor, Team 8-13, Williams Fall 2014 Miembro de Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Miembros
5 Guías creadas
5 comentarios
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Brucereno2 - Contestar
Did you ever find a speaker for your jabra cruiser?
Scot Tetreault -
halo
where i can get the new speaker for jabra cruiser 2?
Frantisek Fridrich - Contestar
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
A 36 mm speaker will also fit nicely. A 1 watt 8 ohms speaker is the best choice - the amplifier is not able to output enough power to drive a 2+ watt speaker.
Mobi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 1,886
