Saltar al contenido principal
Jabra CRUISER2 Motherboard Replacement
Qué necesitas
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: paso 1, imagen 1 de 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Instrucciones de iOpener
  2. Jabra CRUISER2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: paso 3, imagen 1 de 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 Jabra CRUISER2 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: paso 5, imagen 1 de 1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the motherboard from the device by lifting it up from the back plate.
Conclusión
Spartacus
Miembro Desde 10/17/14
636 Reputación
5 Guías creadas
Equipo
Baylor, Team 8-13, Williams Fall 2014 Miembro de Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 789
