Introducción
This guide explains how to replace the power button for a JVC XL-333 compact disc player. The steps are fairly simple, and you only need a few basic tools. Most of the steps only require either removing screws or using a spudger (or similar tool) to remove wires that are in the way.
Qué necesitas
Using your Phillips Head Screwdriver, remove the four screws with the red markup.
Then, remove the three orange screws using your screwdriver.
Herramienta utilizada en este paso:Tweezers$4.99
Gently pull up to remove the two bunches of wires with a green connector from the motherboard.
Remove the two groups of wires with a white connector by using your spudger or tweezers to pull up on the side of the connector, opposite of the wires. It may require some force
Find the power button trigger on the left side of the CD Player. It should be gray.
Push it a couple times to make sure it works. If not hold it 3/4 of the way and pull with some force.
Replace with a new one.
Replace the motherboard, reattach the cables and repeat the rest of the previous tasks in reverse.
