Introducción
The disc drive of this device can be removed and replaced with moderate ease. A spare disc drive, or DVD mechanism can be found here.
Qué necesitas
Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
Remove the top panel.
After removing all screws and top panel, lift up disc drive from steel enclosure.
Casi Terminas!
Conclusión
