Introducción
The disc drive of this device can be removed and replaced with moderate ease. A spare disc drive, or DVD mechanism can be found here.
  1. Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver. Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver. Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver. Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers. Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers. Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. Gently remove the front panel from the steel enclosure.
    • Gently remove the front panel from the steel enclosure.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger. Be careful not to scratch or damage components or features of the circuit board with the metal spudger Be careful not to scratch or damage components or features of the circuit board with the metal spudger
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  7. Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver. Remove the top panel. Remove the top panel.
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  8. After removing all screws and top panel, lift up disc drive from steel enclosure.
    • After removing all screws and top panel, lift up disc drive from steel enclosure.
  9. Turn over the disc drive to expose the connector.
    • Turn over the disc drive to expose the connector.
    • Gently remove the ribbon cable from the ZIF on the circuit board using the metal spudger.
  10. Gently pull to remove the electrical connector from disc drive. Gently pull to remove the electrical connector from disc drive. Gently pull to remove the electrical connector from disc drive.
    • Gently pull to remove the electrical connector from disc drive.
  11. Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver. Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
    • Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
  12. Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver. Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 97
