Saltar al contenido principal
JVC GR-D72U Cassette Holder Replacement
Qué necesitas
  1. JVC GR-D72U Cassette Holder Replacement, Battery: paso 1, imagen 1 de 2 JVC GR-D72U Cassette Holder Replacement, Battery: paso 1, imagen 2 de 2
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Cassette Holder Replacement: paso 2, imagen 1 de 1
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Cassette Holder Replacement, Lateral Function Port Panel: paso 3, imagen 1 de 3 JVC GR-D72U Cassette Holder Replacement, Lateral Function Port Panel: paso 3, imagen 2 de 3 JVC GR-D72U Cassette Holder Replacement, Lateral Function Port Panel: paso 3, imagen 3 de 3
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Cassette Holder Replacement: paso 4, imagen 1 de 1
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Cassette Holder Replacement: paso 5, imagen 1 de 1
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Cassette Holder Replacement: paso 6, imagen 1 de 1
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Cassette Holder Replacement: paso 7, imagen 1 de 1
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Cassette Holder Replacement: paso 8, imagen 1 de 1
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Cassette Holder Replacement: paso 9, imagen 1 de 3 JVC GR-D72U Cassette Holder Replacement: paso 9, imagen 2 de 3 JVC GR-D72U Cassette Holder Replacement: paso 9, imagen 3 de 3
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
  10. JVC GR-D72U Cassette Holder Replacement, Cassette Holder: paso 10, imagen 1 de 1
    • From the inside of the camera remove these six screws.
    • 3.3 mm
    • 3.6 mm
    • 3.1 mm
    • 4.3 mm
    • 4.3 mm
    • 3.7 mm
  11. JVC GR-D72U Cassette Holder Replacement: paso 11, imagen 1 de 1
    • Unplug the three cables from the circuit board.
  12. JVC GR-D72U Cassette Holder Replacement: paso 12, imagen 1 de 3 JVC GR-D72U Cassette Holder Replacement: paso 12, imagen 2 de 3 JVC GR-D72U Cassette Holder Replacement: paso 12, imagen 3 de 3
    • From the top of the camera remove the two 3.1 mm screws securing the lens to the camera frame.
    • From the bottom of the camera remove the 3.2 mm screw next to the battery release switch.
    • Remove the 9.1 mm screw next to the menu and volume control label.
  13. JVC GR-D72U Cassette Holder Replacement: paso 13, imagen 1 de 2 JVC GR-D72U Cassette Holder Replacement: paso 13, imagen 2 de 2
    • Remove the lens cap housing.
    • Remove the two 3.1 mm screws from the inside of the camera.
  14. JVC GR-D72U Cassette Holder Replacement: paso 14, imagen 1 de 3 JVC GR-D72U Cassette Holder Replacement: paso 14, imagen 2 de 3 JVC GR-D72U Cassette Holder Replacement: paso 14, imagen 3 de 3
    • Remove the plastic cover piece next to the silver light button.
    • Remove the 3.1 mm screw securing the lens to the circuit board.
    • Remove the two 3.3 mm screws from underneath the battery port.
  15. JVC GR-D72U Cassette Holder Replacement: paso 15, imagen 1 de 2 JVC GR-D72U Cassette Holder Replacement: paso 15, imagen 2 de 2
    • Take the cassette holder and circuit board by lifting it out of the camera frame.
    • Remove the two 3.6 mm screws.
    • Remove the two 1.8 mm screws then the plate.
    • If you are following this guide to replace the LED light or microphone you do not need to follow this step or the next step.
  16. JVC GR-D72U Cassette Holder Replacement: paso 16, imagen 1 de 3 JVC GR-D72U Cassette Holder Replacement: paso 16, imagen 2 de 3 JVC GR-D72U Cassette Holder Replacement: paso 16, imagen 3 de 3
    • Remove the six cables (one is underneath the metal plate) connecting the cassette holder to the circuit board.
    • To unplug two of the cables you must first pull the lock tabs out (towards the cable) then remove the cable.
Conclusión
Una persona más ha completado esta guía.
Jonah Powers
Miembro Desde 09/28/17
422 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S2-G2, Nance Fall 2017 Miembro de USF Tampa, Team S2-G2, Nance Fall 2017
USFT-NANCE-F17S2G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 957
