Saltar al contenido principal
JVC Adixxion GC-XA1BU Lens (External) Replacement
Qué necesitas
  1. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery: paso 1, imagen 1 de 1
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 2, imagen 1 de 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 3, imagen 1 de 1
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 4, imagen 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 4, imagen 2 de 2
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 5, imagen 1 de 1
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery Cover: paso 6, imagen 1 de 1
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): paso 7, imagen 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): paso 7, imagen 2 de 2
    • Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 8, imagen 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 8, imagen 2 de 2
    • Twist the metal ring on the lens to the right and then pull it off.
  9. JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 9, imagen 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: paso 9, imagen 2 de 2
    • Use the plastic opening tool to gently pry the lens off of the camera.
Conclusión
Equipo
USF Tampa, Team 1-2, Tanski Winter 2015 Miembro de USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Miembros
8 Guías creadas
Un comentario
Where can the lens be purchased at?
Isaac Aguilar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 623
