Saltar al contenido principal
JVC Adixxion GC-XA1BU LCD Screen Replacement
Qué necesitas
  1. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 2, imagen 1 de 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 3, imagen 1 de 1
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 4, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 4, imagen 2 de 2
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery Cover: paso 6, imagen 1 de 1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: paso 7, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: paso 7, imagen 2 de 2
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
  8. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 8, imagen 1 de 1
    • Carefully open the camera as shown and gently peel off the black cover tape.
  9. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 9, imagen 1 de 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 9, imagen 2 de 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 9, imagen 3 de 3
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
  10. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 10, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 10, imagen 2 de 2
    • Carefully grasp and remove the ribbon cable using the tweezers.
  11. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 11, imagen 1 de 1
    • Turn the camera as shown and carefully remove the glue from the connector.
  12. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 12, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 12, imagen 2 de 2
    • Carefully pull the white clip out of the casing using the tweezers.
  13. JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: paso 13, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: paso 13, imagen 2 de 2
    • Remove the top two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver before removing the silver plate with the tweezers. Use a Phillips #00 screwdriver to remove the two top screws (4mmx x 3mm). Once the screws are removed, carefully lift off the silver plate using Tweezers.
  14. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 14, imagen 1 de 1
    • Once you have lifted and removed the silver plate, use a Phillips #00 screwdriver to remove the two bottom screws (4mm x 3mm).
  15. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 15, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 15, imagen 2 de 2
    • Using Tweezers, gently pull the red, black, and white threaded wire to disconnect it, then remove the attached panel as shown.
  16. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: paso 16, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: paso 16, imagen 2 de 2
    • Carefully lift up and remove the LCD screen using the tweezers.
  17. JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 17, imagen 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: paso 17, imagen 2 de 2
    • The screen as shown if removed properly.
Conclusión
Follow these steps in reverse order with the new LCD screen in order to complete the replacement.
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-2, Tanski Winter 2015 Miembro de USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 682
