Saltar al contenido principal
JVC Adixxion GC-XA1BU Battery Housing Replacement
Qué necesitas
  1. JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery: paso 1, imagen 1 de 1
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 2, imagen 1 de 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 3, imagen 1 de 1
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 4, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 4, imagen 2 de 2
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery Cover: paso 6, imagen 1 de 1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU Battery Housing Replacement, LCD Cover: paso 7, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement, LCD Cover: paso 7, imagen 2 de 2
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
  8. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 8, imagen 1 de 1
    • Carefully open the camera as shown and gently peel off the black cover tape.
  9. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 9, imagen 1 de 3 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 9, imagen 2 de 3 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 9, imagen 3 de 3
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
  10. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 10, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 10, imagen 2 de 2
    • Carefully grasp and remove the ribbon cable using the tweezers.
  11. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 11, imagen 1 de 1
    • Turn the camera as shown and carefully remove the glue from the connector.
  12. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 12, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 12, imagen 2 de 2
    • Carefully pull the white clip out of the casing using the tweezers.
  13. JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery Housing: paso 13, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery Housing: paso 13, imagen 2 de 2
    • Carefully peel off the glue holding the red and black braided wire down to the circuit board. Then remove the connector by gently pulling it out of its casing. You will want to save this glue as it may come in handy when re-assembling your device.
  14. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 14, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 14, imagen 2 de 2
    • Lift up the white ribbon clip and remove the black ribbon by gently pulling it away from the white clip.
  15. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 15, imagen 1 de 1
    • Remove the the three Phillips screws (3mm headsize x 2mm length) from the circuit board. After you remove the screws, you can then remove the green circuit board by lifting it up out of the device case. You may want to use the plastic opening tool to get start lifting the circuit board.
  16. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 16, imagen 1 de 1
    • Once the circuit board is removed, you will want to remove the Phillips screw (3mm headsize x 2 mm length) near the ribbon cable. ONLY REMOVE THIS ONE SCREW.
  17. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 17, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 17, imagen 2 de 2
    • Use the plastic opening tool to gently remove the top cover from the camera. It is glued on, so you may need to work at it to get it to come off.
  18. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 18, imagen 1 de 1
    • Once the cover has been removed, you will want to remove the three Phillips screws (2mm headsize x 2mm length) that are underneath.
  19. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 19, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 19, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Carefully remove both the top and bottom copper strips by gently pulling them off with the tweezers.
  20. JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 20, imagen 1 de 2 JVC Adixxion GC-XA1BU Battery Housing Replacement: paso 20, imagen 2 de 2
    • Now you should be able to gently remove the battery housing out of the device. If you are having difficulty getting the battery housing to come out, you may want to use the plastic opening tool to help get it started.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-2, Tanski Winter 2015 Miembro de USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Miembros
8 Guías creadas
Un comentario
I couldn't save the glue from the top cover in order to reassembly it. Does this glue has the function to repel the water or its main function is just to glue together the top cover?
Spencer Chedid - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,757
