Introducción
This guide will help you identify the location of the wireless antenna that receives Wi-Fi signal, and how to properly replace it.
Qué necesitas
The tools needed in order to complete this task are above in the tools section.
Grab your tablet and have your tools ready in order to open it and fix the components inside.
Now grab your iFixit prying tool and try to carefully pry off the back casing.
The back doesn't want to dislodge easily so make sure the end of your pry tool is underneath the screen in order to get enough leverage to start popping off the back case from the screen.
Be careful when prying the edge of your tablet! Avoid snapping the volume and lock buttons. Also try not to dig into the tablet too deep with your prying tool so you don't damage any components inside.
Locate antenna end above battery
The antenna will be located next to the plastic fixture for the speaker
Antenna will wrap around the side of the battery and lead to the motherboard
