Introducción
In this guide we're teaching the users of the JLab Pro-7 how to replace the front facing camera. This is a rather quick and easy guide. We outlined comprehensive and easy steps so anyone can do this.
Qué necesitas
The tools needed in order to complete this task are above in the tools section.
Grab your tablet and have your tools ready in order to open it and fix the components inside.
Now grab your iFixit prying tool and try to carefully pry off the back casing.
The back doesn't want to dislodge easily so make sure the end of your pry tool is underneath the screen in order to get enough leverage to start popping off the back case from the screen.
Be careful when prying the edge of your tablet! Avoid snapping the volume and lock buttons. Also try not to dig into the tablet too deep with your prying tool so you don't damage any components inside.
This guide will show you how to remove the front facing camera.
At the top right of the motherboard there is a ribbon cable. The red rectangle shows where we are referring to.
