Saltar al contenido principal
JIAYU F1 Battery Replacement
Qué necesitas
  1. JIAYU F1 Battery Replacement, Turn Off the Phone: paso 1, imagen 1 de 1
    • Turn the phone off by holding down the power button located on the top of the phone.
  2. JIAYU F1 Battery Replacement, Remove the Back Case: paso 2, imagen 1 de 3 JIAYU F1 Battery Replacement, Remove the Back Case: paso 2, imagen 2 de 3 JIAYU F1 Battery Replacement, Remove the Back Case: paso 2, imagen 3 de 3
    • Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool.
    • Gently remove the back case completely from the phone.
  3. JIAYU F1 Battery Replacement, Remove the Battery: paso 3, imagen 1 de 3 JIAYU F1 Battery Replacement, Remove the Battery: paso 3, imagen 2 de 3 JIAYU F1 Battery Replacement, Remove the Battery: paso 3, imagen 3 de 3
    • Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward.
    • Remove the battery from the phone.
    • When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
Conclusión
Una persona más ha completado esta guía.
Samantha Fruge
Miembro Desde 10/08/14
230 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 9-4, Leahy Fall 2014 Miembro de USF Tampa, Team 9-4, Leahy Fall 2014
USFT-LEAHY-F14S9G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 531
