Saltar al contenido principal
JD Razor 2000 Front Wheel Replacement
Qué necesitas
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: paso 1, imagen 1 de 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: paso 1, imagen 2 de 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: paso 1, imagen 3 de 3
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: paso 2, imagen 1 de 1
    • Grip the bottom of the wheel and gently slide it out.
Conclusión
Kaylan Naicker
Miembro Desde 10/14/14
255 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-46, Amido Fall 2014 Miembro de Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 904
