Saltar al contenido principal
JBL Xtreme Cover Disassembly
Qué necesitas
  1. JBL Xtreme Cover Disassembly, Cover: paso 1, imagen 1 de 1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Cover Disassembly: paso 2, imagen 1 de 2 JBL Xtreme Cover Disassembly: paso 2, imagen 2 de 2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Cover Disassembly: paso 3, imagen 1 de 2 JBL Xtreme Cover Disassembly: paso 3, imagen 2 de 2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Conclusión
14 personas más completaron esta guía.
Benny Huynh
Miembro Desde 02/15/17
1,929 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-1, Sullivan Spring 2017 Miembro de USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 Miembros
27 Guías creadas
5 comentarios
Can you fix my cover on speaker
c_pg08 - Contestar
where can I find a new cover for xtreme 2, if possible in black?
vale0501 - Contestar
If you find a place to buy a cover let me know
abjayaman -
you forgot about 2 screws
Enescu Catalin - Contestar
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
megakacper11 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 37
Ultimos 30 días: 181
Todo El Tiempo: 30,385
