Introducción
This Guide will help you replace the battery inside a JBL Xtreme Bluetooth Speaker.
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
Locate the three 9.7mm Phillips head screws inside the zipper compartment and unscrew them.
Lift the zipper panel out of the speaker.
58 personas más completaron esta guía.
26 comentarios
I couldn't find the battery specification anywhere in the Internet, so I removed it, easily following the well presented instructions above. The battery has two cells. The label on each cell says Greatpower, model no. GSP0931134, 7.4 volts, 5000 mah, 37Wh, made in China. Overall dimensions are 145mm x 32mm x 19mm (145mm includes a small electronic board where cables from the board connect to the plug.) After an Amazon and Google search, I'm no closer to a replacement. At least the reassembled Xtreme works without a battery with external power. JBL is of no help, either. I'll be looking model airplane stores, as they have every LiPo battery imaginable. In summary, the JBL Xtreme is a short lived unsupported product.
This is kinda late but were there any extra steps for running the speaker without a battery? Since the speaker is not working anymore at all, even with power connected, I would be happy to run it like this but am not sure whether it is really enough to just remove the battery.
this &&^&^$^ jbl costumer support service is charging me $110 for battery replacement, and a $30 service charge, it cost half of the speaker price,
Same here in Hungary.
I’ve got a battery issue (a full charge lasts only about 3-4 hours of playback on mid volume) after a little more than 1 year of usage…
110 US dollars for replacement. Nonsense!
