Saltar al contenido principal
JBL Xtreme 3 Battery Replacement
Qué necesitas
  1. JBL Xtreme 3 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: paso 3, imagen 1 de 2 JBL Xtreme 3 Battery Replacement: paso 3, imagen 2 de 2
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
  4. JBL Xtreme 3 Battery Replacement: paso 4, imagen 1 de 2 JBL Xtreme 3 Battery Replacement: paso 4, imagen 2 de 2
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: paso 5, imagen 1 de 2 JBL Xtreme 3 Battery Replacement: paso 5, imagen 2 de 2
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: paso 6, imagen 1 de 3 JBL Xtreme 3 Battery Replacement: paso 6, imagen 2 de 3 JBL Xtreme 3 Battery Replacement: paso 6, imagen 3 de 3
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
Conclusión
5 personas más completaron esta guía.
Un comentario
Great guide! Thank you!
dam damo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 43
Ultimos 30 días: 183
Todo El Tiempo: 2,496
