Saltar al contenido principal
JBL Xtreme 2 Speaker Replacement
Qué necesitas
  1. JBL Xtreme 2 Speaker Replacement, Speaker: paso 1, imagen 1 de 2 JBL Xtreme 2 Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Use a spudger or other prying tool to gently pry open the middle section of the speaker.
  2. JBL Xtreme 2 Speaker Replacement: paso 2, imagen 1 de 2 JBL Xtreme 2 Speaker Replacement: paso 2, imagen 2 de 2
    • To open the case, open the front side gently rotating along the hinge.
  3. JBL Xtreme 2 Speaker Replacement: paso 3, imagen 1 de 1
    • Once you have the speakers exposed like in the image, at the bottom part you will snap open the back end piece of the grill still attached.
  4. JBL Xtreme 2 Speaker Replacement: paso 4, imagen 1 de 3 JBL Xtreme 2 Speaker Replacement: paso 4, imagen 2 de 3 JBL Xtreme 2 Speaker Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the four 12.9 mm screws securing the faulty speaker.
    • Once you remove the screws, the speaker will be loose and you will be able to move it around easily.
  5. JBL Xtreme 2 Speaker Replacement: paso 5, imagen 1 de 3 JBL Xtreme 2 Speaker Replacement: paso 5, imagen 2 de 3 JBL Xtreme 2 Speaker Replacement: paso 5, imagen 3 de 3
    • Lift the speaker out of its housing and you will see two cables connecting the speaker. Pull the speaker towards you and each of the cable connectors away from you.
    • Do the same for both cables.
Conclusión
2 personas más completaron esta guía.
charlymoron
Miembro Desde 10/30/22
169 Reputación
1 Guía escrita
Equipo
Un comentario
Jep u open it wrong way. I broken My speaker Plastic attachment so i need extra work whit wrong opening way. I can sent u a some pic whit this.
Bender - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 126
Todo El Tiempo: 2,295
