Saltar al contenido principal
JBL Spyro/Spot Partial Disassembly
Qué necesitas
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: paso 1, imagen 1 de 1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: paso 2, imagen 1 de 1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: paso 3, imagen 1 de 1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
Conclusión
17 personas más completaron esta guía.
Ryan McLeod
Miembro Desde 05/22/10
606 Reputación
2 Guías creadas
11 comentarios
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - Contestar
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - Contestar
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 23
Ultimos 30 días: 110
Todo El Tiempo: 13,073
