Saltar al contenido principal
JBL Pulse 3 Speaker Grill Replacement
Qué necesitas
  1. JBL Pulse 3 Speaker Grill Replacement, Speaker Grill: paso 1, imagen 1 de 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Speaker Grill Replacement: paso 2, imagen 1 de 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Speaker Grill Replacement: paso 3, imagen 1 de 2 JBL Pulse 3 Speaker Grill Replacement: paso 3, imagen 2 de 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
Conclusión
To reassemble your device, follow the instructions in reverse order.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 22
Todo El Tiempo: 931
