Introducción
The motherboard for the JBL Pulse 3 is located inside the LED light display next to the battery.
Qué necesitas
Lay the JBL Pulse 3 on its side as shown in the picture.
Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
Pull the LED light display off of the JBL Pulse 3 base.
Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
Note: To replace the motherboard, you will need to re-solder the black wire to the motherboard.
2 personas más completaron esta guía.
Un comentario
tengo un pulse 3 que la placa entro en corto… me gustaria saber si alguien me puede ayudar con el diagrama esquematico o algun foto donde pueda conseguir
