Saltar al contenido principal
JBL Pulse 2 Speaker Replacement
Qué necesitas
  1. JBL Pulse 2 Speaker Replacement, Battery: paso 1, imagen 1 de 2 JBL Pulse 2 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Speaker Replacement: paso 4, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 4, imagen 2 de 2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Speaker Replacement: paso 5, imagen 1 de 3 JBL Pulse 2 Speaker Replacement: paso 5, imagen 2 de 3 JBL Pulse 2 Speaker Replacement: paso 5, imagen 3 de 3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Speaker Replacement: paso 7, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 7, imagen 2 de 2
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Speaker Replacement: paso 8, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 8, imagen 2 de 2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Speaker Replacement: paso 9, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 9, imagen 2 de 2
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Speaker Replacement: paso 10, imagen 1 de 1
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Speaker Replacement: paso 11, imagen 1 de 1
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Speaker Replacement: paso 12, imagen 1 de 1
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Speaker Replacement: paso 13, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 13, imagen 2 de 2
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Speaker Replacement: paso 14, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 14, imagen 2 de 2
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Speaker Replacement: paso 15, imagen 1 de 1
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
  16. JBL Pulse 2 Speaker Replacement, Speaker: paso 16, imagen 1 de 3 JBL Pulse 2 Speaker Replacement, Speaker: paso 16, imagen 2 de 3 JBL Pulse 2 Speaker Replacement, Speaker: paso 16, imagen 3 de 3
    • Remove the LED strips from the outside of the white plastic casing.
  17. JBL Pulse 2 Speaker Replacement: paso 17, imagen 1 de 3 JBL Pulse 2 Speaker Replacement: paso 17, imagen 2 de 3 JBL Pulse 2 Speaker Replacement: paso 17, imagen 3 de 3
    • Use the Phillips #1 screwdriver to remove the ten 9.5mm screws that hold the cage in place.
    • Lift the cage off to access the internal components.
  18. JBL Pulse 2 Speaker Replacement: paso 18, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 18, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.4mm screws that hold the speakers in place.
    • Partially remove the speakers so that you can access the components underneath them.
  19. JBL Pulse 2 Speaker Replacement: paso 19, imagen 1 de 2 JBL Pulse 2 Speaker Replacement: paso 19, imagen 2 de 2
    • Use the straight tweezers to disconnect the speakers from the motherboard.
    • Fully remove the speakers once they are disconnected from the motherboard.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 22
Todo El Tiempo: 1,587
