Saltar al contenido principal
JBL Flip Speaker Replacement
Qué necesitas
  1. JBL Flip Speaker Replacement, JBL Flip disassembly: paso 1, imagen 1 de 3 JBL Flip Speaker Replacement, JBL Flip disassembly: paso 1, imagen 2 de 3 JBL Flip Speaker Replacement, JBL Flip disassembly: paso 1, imagen 3 de 3
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
  2. JBL Flip Speaker Replacement: paso 2, imagen 1 de 3 JBL Flip Speaker Replacement: paso 2, imagen 2 de 3 JBL Flip Speaker Replacement: paso 2, imagen 3 de 3
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
  3. JBL Flip Speaker Replacement: paso 3, imagen 1 de 3 JBL Flip Speaker Replacement: paso 3, imagen 2 de 3 JBL Flip Speaker Replacement: paso 3, imagen 3 de 3
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
  4. JBL Flip Speaker Replacement: paso 4, imagen 1 de 1
    • Remove last white back plate to expose the back of the speaker cover.
  5. JBL Flip Speaker Replacement: paso 5, imagen 1 de 3 JBL Flip Speaker Replacement: paso 5, imagen 2 de 3 JBL Flip Speaker Replacement: paso 5, imagen 3 de 3
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
  6. JBL Flip Speaker Replacement: paso 6, imagen 1 de 3 JBL Flip Speaker Replacement: paso 6, imagen 2 de 3 JBL Flip Speaker Replacement: paso 6, imagen 3 de 3
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
  7. JBL Flip Speaker Replacement, Speaker: paso 7, imagen 1 de 3 JBL Flip Speaker Replacement, Speaker: paso 7, imagen 2 de 3 JBL Flip Speaker Replacement, Speaker: paso 7, imagen 3 de 3
    • Remove screws that hold the plastic L-pipe in place.
  8. JBL Flip Speaker Replacement: paso 8, imagen 1 de 2 JBL Flip Speaker Replacement: paso 8, imagen 2 de 2
    • Remove L-pipe.
    • Remove two screws on each speaker.
    • Remove speakers.
  9. JBL Flip Speaker Replacement: paso 9, imagen 1 de 3 JBL Flip Speaker Replacement: paso 9, imagen 2 de 3 JBL Flip Speaker Replacement: paso 9, imagen 3 de 3
    • Take a soldering iron to the two solders, one for each cable.
    • Soldering iron will be very hot.
    • Once the soldering has melted, remove each wire from the speaker.
Conclusión
6 personas más completaron esta guía.
Dillon
Miembro Desde 03/11/15
1,556 Reputación
5 Guías creadas
Equipo
9 comentarios
I want JBL flip 2 charging commector board.
Where can i buy ??
Plz help me
feroz4u786 - Contestar
Where do you buy the replacement speakers?
ingridxpan - Contestar
I have a problem with the bluetooth of my speaker goes off after 10 minutes of running I have checked with several smart and it always repeats that I can do
Alvaro Rivas Rodriguez - Contestar
Where I can get schematic diagram and plans of this equipment
I want to buy 2pcs replacement speaker for my JBL flip bluetooth speaker. Ho can I buy .and from
jonessangeeta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 75
Todo El Tiempo: 41,958
