Introducción
The outer case replacement or simply removal is a good place to start if you need to replace the outer case or if you need to replace or repair anything inside the JBL Flip 5. Once removed, it's a good idea to check for dirt buildup or anything that might be under the case that might affect device performance.
Qué necesitas
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
