Saltar al contenido principal
JBL Flip 5 Outer Case Replacement
Qué necesitas
  1. JBL Flip 5 Outer Case Replacement, Outer Case: paso 1, imagen 1 de 2 JBL Flip 5 Outer Case Replacement, Outer Case: paso 1, imagen 2 de 2
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
  2. JBL Flip 5 Outer Case Replacement: paso 2, imagen 1 de 1
    • Once all the clips are released, you will be able to pull up that edge of the case.
  3. JBL Flip 5 Outer Case Replacement: paso 3, imagen 1 de 1
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
  4. JBL Flip 5 Outer Case Replacement: paso 4, imagen 1 de 2 JBL Flip 5 Outer Case Replacement: paso 4, imagen 2 de 2
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
Conclusión
Jackson Tillinghast
Miembro Desde 10/30/23
303 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-5, Konn Fall 2023 Miembro de UMass Dartmouth, Team 3-5, Konn Fall 2023
UMASSD-KONN-F23S3G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 51
Todo El Tiempo: 208
