Saltar al contenido principal
JBL Flip 4 Battery Replacement
Qué necesitas
  1. JBL Flip 4 Battery Replacement, Shell: paso 1, imagen 1 de 3 JBL Flip 4 Battery Replacement, Shell: paso 1, imagen 2 de 3 JBL Flip 4 Battery Replacement, Shell: paso 1, imagen 3 de 3
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 Battery Replacement: paso 2, imagen 1 de 3 JBL Flip 4 Battery Replacement: paso 2, imagen 2 de 3 JBL Flip 4 Battery Replacement: paso 2, imagen 3 de 3
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
  3. JBL Flip 4 Battery Replacement, Battery: paso 3, imagen 1 de 3 JBL Flip 4 Battery Replacement, Battery: paso 3, imagen 2 de 3 JBL Flip 4 Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Remove five 9mm Phillips #1 screws from the end cap opposite to the USB port.
    • Pull the end cap off with your hands.
  4. JBL Flip 4 Battery Replacement: paso 4, imagen 1 de 3 JBL Flip 4 Battery Replacement: paso 4, imagen 2 de 3 JBL Flip 4 Battery Replacement: paso 4, imagen 3 de 3
    • Remove two 11mm Phillips #1 screws on the battery cover.
    • Pull the battery cover off with your hands.
  5. JBL Flip 4 Battery Replacement: paso 5, imagen 1 de 3 JBL Flip 4 Battery Replacement: paso 5, imagen 2 de 3 JBL Flip 4 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the large white plug that connects the wires from the battery to the main board using your hands.
    • Pull the battery out with your hands.
    • If the battery is swollen, you might not be able to pull it out with your hands, you might just rip the cables+charging board out.
    • In this case, you can try to remove the other radiator, unscrew the charging port and gently pull it out just a bit so a large screwdriver's end - without its bits - can fit in and push out the battery from this side.
    • The port might be hot glued and under the tapes there are very small normal and ribbon cables, so be careful not to cut or rip them.
Conclusión
148 personas más completaron esta guía.
Philip Pang
Miembro Desde 10/08/18
1,249 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G3, White Fall 2018 Miembro de Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Miembros
36 Guías creadas
63 comentarios
Is the battery glued into the socket like the Flip 3?
Kenneth - Contestar
No it isn’t. but the black rubber around it makes it really hard to get out. try to push it from the otherside by removing the charging-port.
Be careful not to pierce the battery
Richardo Otros -
Yes with me the battery was glued
Diter Freeman -
Be careful and don’t do like me: my old battery was bloated, so I had to push from the other side, but when doing so, I ripped the ribbon cable from the power button… now trying to find a replacement cable
jmbarroso -
Did you find the cable of the power button?
mohamed da -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 132
Ultimos 7 días: 755
Ultimos 30 días: 3,458
Todo El Tiempo: 217,886
