Saltar al contenido principal
JBL Flip 3 Speaker Replacement
Qué necesitas
  1. JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 1: paso 1, imagen 1 de 3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 1: paso 1, imagen 2 de 3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 1: paso 1, imagen 3 de 3
    • Using a pry opening tool, pry into the speaker grill covering as seen in the photos.
  2. JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 2: paso 2, imagen 1 de 3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 2: paso 2, imagen 2 de 3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 2: paso 2, imagen 3 de 3
    • Continue to pry open the grill all the way around until it can be removed from the unit itself as seen in the pictures.
  3. JBL Flip 3 Speaker Replacement, Remove Speaker Screws: paso 3, imagen 1 de 1
    • Remove all 8 speaker screws using a Philips 00 screwdriver.
  4. JBL Flip 3 Speaker Replacement, Remove Speaker from Housing: paso 4, imagen 1 de 2 JBL Flip 3 Speaker Replacement, Remove Speaker from Housing: paso 4, imagen 2 de 2
    • Using a pry tool, remove speakers from housing as seen in the picture.
  5. JBL Flip 3 Speaker Replacement, Remove Speaker Connection: paso 5, imagen 1 de 2 JBL Flip 3 Speaker Replacement, Remove Speaker Connection: paso 5, imagen 2 de 2
    • Using tweezers, carefully remove both side speakers from the motherboard as shown in the pictures.
Conclusión
17 personas más completaron esta guía.
Faizan Naveed
Miembro Desde 04/12/17
3,294 Reputación
8 Guías creadas
Equipo
Mobile Device Repair Factory Miembro de Mobile Device Repair Factory
Business
1 Miembro
16 Guías creadas
16 comentarios
where did you aquire the replacement drivers?
djbadandy - Contestar
where did you get the drivers from?
Rashid Saad Siddiqui - Contestar
Sir
My JBL speaker is brust plz help me
Anil Kumar Hembrom - Contestar
ANIL KUMAR HEMBROM - Contestar
My JBL speaker is brust plz help me ….
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 37
Ultimos 30 días: 105
Todo El Tiempo: 24,999
