Saltar al contenido principal
JBL Flip 3 Front Active Driver Replacement
Qué necesitas
  1. JBL Flip 3 Front Active Driver Replacement, Front Active Driver: paso 1, imagen 1 de 1
    • Remove plastic outer housing using hands or a standard spudger.
  2. JBL Flip 3 Front Active Driver Replacement: paso 2, imagen 1 de 1
    • Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
  3. JBL Flip 3 Front Active Driver Replacement: paso 3, imagen 1 de 1
    • Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
  4. JBL Flip 3 Front Active Driver Replacement: paso 4, imagen 1 de 1
    • Remove the 3-pin connector from motherboard.
Conclusión
16 personas más completaron esta guía.
College Student
Miembro Desde 02/22/17
3,479 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S1-G2, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Miembros
17 Guías creadas
7 comentarios
where did you source the drivers from?
Rashid Saad Siddiqui - Contestar
hi my flip 3 1 speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
manu - Contestar
I too want to know where you can buy new drivers. Can't find them online so far...
Johannes - Contestar
i need help getting the front speakers only where would i get them???
brian ortiz - Contestar
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
Anil Kumar Hembrom - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 96
Todo El Tiempo: 19,364
