Partes
Remove plastic outer housing using hands or a standard spudger.
Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
Gently heat adhesive located at tip of powerchip to melt the plastic fastening the battery to the housing. Be careful not to melt the plastic housing during heating.
Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
35 personas más completaron esta guía.
23 comentarios
where can I get replacement battery for Flip 3?
It is couple diffrent version of JBL Flip 3 speaker .
my battery also went to !&&*!! anyone manage to get a replacement?? couldn't find one!
In the same boat. Battery died and JBL doesn’t replace them outside of warranty. Can’t find a new one.
