Introducción
Within this guide, the user will learn how to remove the speakers and check if speakers are functioning properly as well as how to replace them.
Qué necesitas
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
28 personas más completaron esta guía.
18 comentarios
Since I wasn’t in the US and shipping cost from the Dayton speakers were prohibitvely, I ended up finding the speakers form China. The upside is that they are easier to install, since you dont have to cut down the lateral support, the downside is that they are 6 Ohms and have a lower quality. Though I worked for me.
Hey, maybe you have the link? :)
What is the size and ohmz and watts of the speaker?
