Saltar al contenido principal
JBL Clip Plus Microphone Replacement
Qué necesitas
  1. JBL Clip Plus Microphone Replacement, Battery: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    $3.99
    Comprar
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Microphone Replacement: paso 2, imagen 1 de 1
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Microphone Replacement: paso 3, imagen 1 de 1
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Microphone Replacement: paso 4, imagen 1 de 1
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Microphone Replacement: paso 5, imagen 1 de 1
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Microphone Replacement: paso 6, imagen 1 de 1
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Microphone Replacement: paso 7, imagen 1 de 1
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Microphone Replacement: paso 8, imagen 1 de 1
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Microphone Replacement: paso 9, imagen 1 de 1
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Microphone Replacement: paso 10, imagen 1 de 1
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Microphone Replacement, Microphone: paso 11, imagen 1 de 1
Conclusión
Una persona más ha completado esta guía.
Noah Pauk
Miembro Desde 02/08/16
809 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-4, Baechle Spring 2016 Miembro de IUPUI, Team 3-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G4
4 Miembros
6 Guías creadas
Un comentario
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
Mic - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 1,875
