Introducción
This guide is to help you replace the internal speaker in a JBL Clip 3.
If the original speaker in your JBL Clip 3 stops working due to a mechanical failure and causes the speaker to produce no sound at all or an unpleasant buzzing or scratching sound, use this guide to replace it with a new speaker.
Note: Before beginning, make sure to power off the JBL Clip 3, and disconnect it from any external power sources.
Qué necesitas
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Una persona más ha completado esta guía.
