Saltar al contenido principal
JBL Clip 3 Speaker Housing Replacement
Qué necesitas
  1. JBL Clip 3 Speaker Housing Replacement, Speaker Grill: paso 1, imagen 1 de 2 JBL Clip 3 Speaker Housing Replacement, Speaker Grill: paso 1, imagen 2 de 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Speaker Housing Replacement, Speaker Housing: paso 2, imagen 1 de 2 JBL Clip 3 Speaker Housing Replacement, Speaker Housing: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Speaker Housing Replacement: paso 3, imagen 1 de 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Speaker Housing Replacement: paso 4, imagen 1 de 2 JBL Clip 3 Speaker Housing Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
Conclusión
2 personas más completaron esta guía.
Kyle Montague
Miembro Desde 03/28/22
238 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 66
Todo El Tiempo: 1,288
