Saltar al contenido principal
JBL Clip 3 Motherboard Replacement
Qué necesitas
  1. JBL Clip 3 Motherboard Replacement, Speaker Grill: paso 1, imagen 1 de 2 JBL Clip 3 Motherboard Replacement, Speaker Grill: paso 1, imagen 2 de 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Motherboard Replacement, Speaker Housing: paso 2, imagen 1 de 2 JBL Clip 3 Motherboard Replacement, Speaker Housing: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Motherboard Replacement: paso 3, imagen 1 de 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Motherboard Replacement: paso 4, imagen 1 de 2 JBL Clip 3 Motherboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Motherboard Replacement, Carabiner Clip: paso 5, imagen 1 de 2 JBL Clip 3 Motherboard Replacement, Carabiner Clip: paso 5, imagen 2 de 2
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 JBL Clip 3 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    Comprar
    • Use a pair of tweezers to release the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Motherboard Replacement: paso 7, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Motherboard Replacement: paso 8, imagen 1 de 2 JBL Clip 3 Motherboard Replacement: paso 8, imagen 2 de 2
    • Lift the motherboard away from the speaker housing.
    • Desolder the two contact points.
Conclusión
Una persona más ha completado esta guía.
Tyler Molden
Miembro Desde 03/28/22
465 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 25
Todo El Tiempo: 664
