Introducción
The Clip 3 is IPX7 waterproof and offers up to 10 hours of playtime, powered by a 1000mAh rechargeable Li-ion battery. If the battery is not charging or holding adequate charge, the battery may require replacement.
This guide will show you the step by step process of replacing a speaker battery for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts on this device, because they can be fragile.
Qué necesitas
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
3 personas más completaron esta guía.
