Saltar al contenido principal
JBL Clip 3 Battery Replacement
Qué necesitas
  1. JBL Clip 3 Battery Replacement, Speaker Grill: paso 1, imagen 1 de 2 JBL Clip 3 Battery Replacement, Speaker Grill: paso 1, imagen 2 de 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Battery Replacement, Speaker Housing: paso 2, imagen 1 de 2 JBL Clip 3 Battery Replacement, Speaker Housing: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Battery Replacement: paso 3, imagen 1 de 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Battery Replacement: paso 4, imagen 1 de 2 JBL Clip 3 Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Battery Replacement, Carabiner Clip: paso 5, imagen 1 de 2 JBL Clip 3 Battery Replacement, Carabiner Clip: paso 5, imagen 2 de 2
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Battery Replacement, Speaker Battery: paso 6, imagen 1 de 2 JBL Clip 3 Battery Replacement, Speaker Battery: paso 6, imagen 2 de 2
    Comprar
    • Use a pair of tweezers to lift the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Battery Replacement: paso 7, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Battery Replacement: paso 8, imagen 1 de 1
    • Gently lift the motherboard away from the speaker housing.
    • Be wary not to unseat the soldered connections when lifting the motherboard.
  9. JBL Clip 3 Battery Replacement: paso 9, imagen 1 de 2 JBL Clip 3 Battery Replacement: paso 9, imagen 2 de 2
    • Use the opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
    • Be mindful not to puncture the battery. It is a Lithium cell, so there is a bit of risk involved when completing this step. Be careful and patient, and there will not be any complications.
    • During reassembly, remember to superglue the new battery back into place.
Conclusión
3 personas más completaron esta guía.
Kyle Montague
Miembro Desde 03/28/22
238 Reputación
2 Guías creadas
Equipo
2 comentarios
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
B.Bender - Contestar
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 86
Ultimos 30 días: 281
Todo El Tiempo: 5,217
