Saltar al contenido principal
JBL Clip 2 Speaker Replacement
Qué necesitas
  1. JBL Clip 2 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: paso 2, imagen 1 de 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: paso 3, imagen 1 de 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: paso 4, imagen 1 de 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
Conclusión
4 personas más completaron esta guía.
Michael Hong
Miembro Desde 02/01/17
1,014 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team 2-2, Rose Winter 2017 Miembro de UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Miembros
7 Guías creadas
6 comentarios
If no parts are required what are you replacing the speaker with?
Tom - Contestar
Tom is right you know!
edward felix - Contestar
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - Contestar
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - Contestar
Hi, where I can buy the speaker please? Thank you.
Govan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 56
Todo El Tiempo: 6,485
