Saltar al contenido principal
JBL Clip 2 Motherboard Replacement
Qué necesitas
  1. JBL Clip 2 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Motherboard Replacement: paso 2, imagen 1 de 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Motherboard Replacement: paso 3, imagen 1 de 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Motherboard Replacement: paso 4, imagen 1 de 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Motherboard Replacement: paso 5, imagen 1 de 1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Motherboard Replacement: paso 6, imagen 1 de 1
    • The motherboard is now exposed, and to extract it you must now desoder the eight connection points to the battery, audio AUX cord, and the Mic.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
Conclusión
2 personas más completaron esta guía.
Michael Hong
Miembro Desde 02/01/17
1,014 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team 2-2, Rose Winter 2017 Miembro de UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 3,583
