Saltar al contenido principal
JBL Clip 2 Audio AUX Cord Replacement
Qué necesitas
  1. JBL Clip 2 Audio AUX Cord Replacement, Audio AUX Cord: paso 1, imagen 1 de 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Audio AUX Cord Replacement: paso 2, imagen 1 de 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws. Save
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Audio AUX Cord Replacement: paso 3, imagen 1 de 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Audio AUX Cord Replacement: paso 4, imagen 1 de 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Audio AUX Cord Replacement: paso 5, imagen 1 de 1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Audio AUX Cord Replacement: paso 6, imagen 1 de 1
Conclusión
3 personas más completaron esta guía.
Michael Hong
Miembro Desde 02/01/17
1,014 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team 2-2, Rose Winter 2017 Miembro de UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Miembros
7 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 3,665
