Introducción
The speakers are located behind the motherboard. Follow this guide to replace one or both broken speakers.
Qué necesitas
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
Using the PH1 screwdriver, remove the 9mm Phillips screw that connects the black tube to the device's interior.
14 personas más completaron esta guía.
12 comentarios
Donde encuentro las bocinas no sirven la que tiene
Donde puedo conseguir las bocinas?
Where can I get gthe replacement speaker?
where can i get replaicment speaker?
