Saltar al contenido principal
JBL Charge Motherboard Replacement
Qué necesitas
  1. JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: paso 1, imagen 1 de 3 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: paso 1, imagen 2 de 3 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: paso 1, imagen 3 de 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Motherboard Replacement: paso 2, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Motherboard Replacement: paso 3, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 3, imagen 2 de 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Motherboard Replacement: paso 4, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 4, imagen 2 de 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Motherboard Replacement: paso 5, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Motherboard Replacement: paso 6, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 6, imagen 2 de 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Motherboard Replacement: paso 7, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 7, imagen 2 de 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Motherboard Replacement: paso 9, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 9, imagen 2 de 2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Motherboard Replacement: paso 10, imagen 1 de 1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Motherboard Replacement: paso 11, imagen 1 de 2 JBL Charge Motherboard Replacement: paso 11, imagen 2 de 2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
Conclusión
7 personas más completaron esta guía.
Jake Bertholf
Miembro Desde 04/01/15
366 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-1, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 Miembros
11 Guías creadas
14 comentarios
Hello I have 3 jbl speakers I bought that work only if plugged to the wall and aux cable... other than that it doesn't work at all .. Bluetooth or even the buttons don't function
hector - Contestar
had same issue. fixed it by reconnecting the cable that conncts LEDs/ buttons
nyancatsarecute -
i have the same problem
Denny Berroa - Contestar
Hello, mine doesn't emit any sound, bluetooth is connected, buttons are working, could it be that some audio cable inside is disconnected?
giubo - Contestar
hello can i ask if how many pins in the flex for power button i accidentally damage when i fixed it
djcriztorey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 70
Todo El Tiempo: 29,972
