Saltar al contenido principal
JBL Charge 5 Fabric Case Replacement
Qué necesitas
  1. JBL Charge 5 Fabric Case Replacement, Fabric Case: paso 1, imagen 1 de 3 JBL Charge 5 Fabric Case Replacement, Fabric Case: paso 1, imagen 2 de 3 JBL Charge 5 Fabric Case Replacement, Fabric Case: paso 1, imagen 3 de 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Fabric Case Replacement: paso 2, imagen 1 de 3 JBL Charge 5 Fabric Case Replacement: paso 2, imagen 2 de 3 JBL Charge 5 Fabric Case Replacement: paso 2, imagen 3 de 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Fabric Case Replacement: paso 3, imagen 1 de 3 JBL Charge 5 Fabric Case Replacement: paso 3, imagen 2 de 3 JBL Charge 5 Fabric Case Replacement: paso 3, imagen 3 de 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 82
Todo El Tiempo: 403
