Saltar al contenido principal
JBL Charge 4 Speaker Replacement
Qué necesitas
  1. JBL Charge 4 Speaker Replacement, Speaker Grill: paso 1, imagen 1 de 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Speaker Replacement: paso 2, imagen 1 de 2 JBL Charge 4 Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Speaker Replacement: paso 3, imagen 1 de 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: paso 4, imagen 1 de 2 JBL Charge 4 Speaker Replacement, Passive Bass Radiators: paso 4, imagen 2 de 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Speaker Replacement: paso 5, imagen 1 de 2 JBL Charge 4 Speaker Replacement: paso 5, imagen 2 de 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 JBL Charge 4 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  7. JBL Charge 4 Speaker Replacement: paso 7, imagen 1 de 1
    • Gently pull out the speaker.
  8. JBL Charge 4 Speaker Replacement: paso 8, imagen 1 de 2 JBL Charge 4 Speaker Replacement: paso 8, imagen 2 de 2
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
Conclusión
10 personas más completaron esta guía.
Rohith Dara
Miembro Desde 01/24/19
357 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S1-G1, White Winter 2019 Miembro de Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Miembros
26 Guías creadas
11 comentarios
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - Contestar
Jbl charge 4 Led indicator board G ribbon cable authentic
carlos maltez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 47
Ultimos 30 días: 198
Todo El Tiempo: 23,056
