Saltar al contenido principal
JBL Charge 4 Buttons Replacement
Qué necesitas
  1. JBL Charge 4 Buttons Replacement, Speaker Grill: paso 1, imagen 1 de 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Buttons Replacement: paso 2, imagen 1 de 2 JBL Charge 4 Buttons Replacement: paso 2, imagen 2 de 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Buttons Replacement: paso 3, imagen 1 de 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Buttons Replacement, Passive Bass Radiators: paso 4, imagen 1 de 2 JBL Charge 4 Buttons Replacement, Passive Bass Radiators: paso 4, imagen 2 de 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Buttons Replacement: paso 5, imagen 1 de 2 JBL Charge 4 Buttons Replacement: paso 5, imagen 2 de 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Buttons Replacement, Buttons: paso 6, imagen 1 de 3 JBL Charge 4 Buttons Replacement, Buttons: paso 6, imagen 2 de 3 JBL Charge 4 Buttons Replacement, Buttons: paso 6, imagen 3 de 3
    • Lift up the tape covering the button control board ZIF connector on the left side of the motherboard.
    • Flip up the black locking flap on the ZIF connector with the tip of the spudger or your fingernail to release the white ribbon cable.
  7. JBL Charge 4 Buttons Replacement: paso 7, imagen 1 de 2 JBL Charge 4 Buttons Replacement: paso 7, imagen 2 de 2
    • Flip the speaker over so the buttons are on the top.
    • Using the plastic opening tool, pry up the rubber covering the button control board from the adhesive.
    • Remove the cover and set to the side.
    • By removing the rubber cover and the control board you are breaking adhesives that may result in the speaker no longer being waterproof.
  8. JBL Charge 4 Buttons Replacement: paso 8, imagen 1 de 3 JBL Charge 4 Buttons Replacement: paso 8, imagen 2 de 3 JBL Charge 4 Buttons Replacement: paso 8, imagen 3 de 3
    • Using the plastic opening tool, pry up the button control board from the adhesive.
    • This will require cutting the adhesive surrounding the board.
    • Gently lift off the button control board feeding the ribbon cable through the slot.
    • When installing a new button control board, make sure to clean all the adhesive residue left by the old board.
Conclusión
13 personas más completaron esta guía.
Zachary Colwell
Miembro Desde 01/24/19
1,944 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G1, White Winter 2019 Miembro de Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Miembros
26 Guías creadas
2 comentarios
Hi - where can I buy the button control board?
Rahman Sayeed - Contestar
How do I boot up JBL CHARGE 4
sashajankovic527 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 57
Ultimos 30 días: 263
Todo El Tiempo: 23,313
