Saltar al contenido principal
JBL Charge 2 Speakers Replacement
Qué necesitas
  1. JBL Charge 2 Speakers Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Speakers Replacement: paso 2, imagen 1 de 2 JBL Charge 2 Speakers Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Speakers Replacement: paso 3, imagen 1 de 2 JBL Charge 2 Speakers Replacement: paso 3, imagen 2 de 2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Speakers Replacement: paso 4, imagen 1 de 2 JBL Charge 2 Speakers Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Speakers Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Speakers Replacement: paso 6, imagen 1 de 3 JBL Charge 2 Speakers Replacement: paso 6, imagen 2 de 3 JBL Charge 2 Speakers Replacement: paso 6, imagen 3 de 3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Speakers Replacement, Speakers: paso 7, imagen 1 de 1
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Speakers Replacement: paso 8, imagen 1 de 1
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Speakers Replacement: paso 9, imagen 1 de 1
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
Conclusión
2 personas más completaron esta guía.
Mauzor Ilonzo
Miembro Desde 09/26/17
495 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S2-G4, Passmore Fall 2017 Miembro de USF Tampa, Team S2-G4, Passmore Fall 2017
USFT-PASSMORE-F17S2G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 49
Todo El Tiempo: 4,643
