Saltar al contenido principal
JBL Charge 2 Plus Passive Radiators Replacement
Qué necesitas
  1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: paso 1, imagen 1 de 2 JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: paso 1, imagen 2 de 2
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Passive Radiators Replacement: paso 2, imagen 1 de 3 JBL Charge 2 Plus Passive Radiators Replacement: paso 2, imagen 2 de 3 JBL Charge 2 Plus Passive Radiators Replacement: paso 2, imagen 3 de 3
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Passive Radiators Replacement: paso 3, imagen 1 de 2 JBL Charge 2 Plus Passive Radiators Replacement: paso 3, imagen 2 de 2
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Passive Radiators Replacement: paso 4, imagen 1 de 1
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Passive Radiators Replacement: paso 5, imagen 1 de 3 JBL Charge 2 Plus Passive Radiators Replacement: paso 5, imagen 2 de 3 JBL Charge 2 Plus Passive Radiators Replacement: paso 5, imagen 3 de 3
    • Repeat Step 2, 3 and 4 for the other passive radiator.
Conclusión
7 personas más completaron esta guía.
John Reynolds
Miembro Desde 10/16/15
3,134 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 4-1, Catania Fall 2015 Miembro de UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Miembros
12 Guías creadas
3 comentarios
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
Jomon johny - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 17,545
