Saltar al contenido principal
JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
Qué necesitas
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: paso 1, imagen 1 de 1
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 2, imagen 1 de 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 2, imagen 2 de 2
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 3, imagen 1 de 1
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 4, imagen 1 de 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 4, imagen 2 de 2
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 5, imagen 1 de 1
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 6, imagen 1 de 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: paso 6, imagen 2 de 2
    • Slide the ribbon gently out of the connector.
Conclusión
17 personas más completaron esta guía.
John Reynolds
Miembro Desde 10/16/15
3,134 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 4-1, Catania Fall 2015 Miembro de UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Miembros
12 Guías creadas
15 comentarios
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - Contestar
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - Contestar
I think it is not normal, if you can find it please contact me! Thanks
I also need to replace my usb connector, has anyone found out where to get one?
Rick - Contestar
need the micro-usb aswell
hellgrenmicke - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 25
Ultimos 30 días: 72
Todo El Tiempo: 26,813
