Saltar al contenido principal
Ivation IVWPDC20Y Display Replacement
Qué necesitas
  1. Ivation IVWPDC20Y Display Replacement, Display: paso 1, imagen 1 de 1
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Display Replacement: paso 2, imagen 1 de 1
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Display Replacement: paso 3, imagen 1 de 1
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit.
  4. Ivation IVWPDC20Y Display Replacement: paso 4, imagen 1 de 1
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit.
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Display Replacement: paso 5, imagen 1 de 1
    • Pry off back outer casing using the black spudger or the blue prying tools.
  6. Ivation IVWPDC20Y Display Replacement: paso 6, imagen 1 de 1
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger.
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure.
  7. Ivation IVWPDC20Y Display Replacement: paso 7, imagen 1 de 1
    • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place.
    • Screen and orange tape should slip out as a whole.
Conclusión
Una persona más ha completado esta guía.
Alex
Miembro Desde 02/08/16
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-6, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 318
